Vacuum Pumps >
Vacuum Pumps
Vacuum Pumps
Old 06-04-2002 | 09:42 AM
INCOGNITO
Default Vacuum Pumps
DOES ANYBODY HAVE OR INSTALLED A VACUUM PUMP ON THEIR ENGINE..WOULD LIKE TO KNOW RESULTS //WHAT KIND OF HEADACHES AND SO ON--HAVE TO PUT ONE ON MINE ,SPITTING OUT TOO MUCH OIL AT HIGHER RPM THRU BREATHERS...I KNOW THE MOTOR WILL MAKE MORE POWER //LOOKS TRICK AND ALL THAT..BUT WITH A CRANK TRIGGER IGNITION IM PROBABLY GOING TO RUN INTO PROBLEMS WITH BELT ALIGNMENT OR SOMETHING..LIKE ALWAYS ITS NEVER AS EASY AS ONE EXPECTS..YOUR THOUGHTS ARE GREATLY APPRECIATED..I KNOW I CANT BE THE ONLY ONE THAT NEEDS 1 OF THESE..AGAIN THANKS FOR SHARING YOUR EXPERIENCE AND KNOWLEDGE.. DID I MENTION ITS A B/B CHEVY WITH A BIG CHIEF HEAD..
Old 06-04-2002 | 09:55 AM
turbo2256
I set mine up with a PCV system works great
Old 09-20-2004 | 11:53 AM
Default Re: Vacuum Pumps
Did you ever install a vacuum pump? Was your engine n/a? Any detectable results? Longevity of pump?
nightmoves is offline
CC247
5
07-09-2007 07:43 PM
boatman22
11-28-2005 09:48 AM
Shah Mat
10
12-23-2002 08:06 AM
DonMan
6
12-17-2002 06:55 PM
