fuel return line ? >
fuel return line ?
fuel return line ?
Old 07-16-2011 | 10:39 AM
Default fuel return line ?
I have a 98 convincor 253 and im looking to see where the return line go's for the fuel system off the fuel rail. The motor is a 98 454 mag mpi with the cool fuel set up. all the diagram i have seen says there is no return. If someone could help me i would appreicate it...
ck253 is offline
Old 07-16-2011 | 12:06 PM
The fuel is returned to the fuel filter head. This is done by Mercury.
Eddie
Young Performance is offline
Old 07-16-2011 | 08:25 PM
only lines that go to and from the fuel filter head go into the cool fuel set up . so there is not one that comes off the rail then?
ck253 is offline
Old 07-17-2011 | 11:44 PM
There is no return from the rail. In the cool fuel box, there is a pump, cooler and regulator. The return line comes from the regulator in the cool fuel box and goes back to the filter head. The regulator comes right off the pump, so the rail is getting fuel that is already regulated. Therefore, there is no need for a return from the rail itself.
Your return line comes from the cool fuel on the port side, across the underside of the engine, and into the fuel filter on the starboard side.
Hope this helps.
Eddie
