Gen 6 ProCharged 502 Big Blocks for Sale
Need to sell my Gen VI 502 cubic inch Procharged motors. Bow Tie Siamese blocks with four bolt mains, aluminum intakes, Mercury water pumps, 1 piece rear main seals, 1053 steel Forged & Cross Drilled Cranks, 4340 Forged Rods with 7/16” bolts, forged pistons, and steel roller camshafts, Rectangular Port heads with 2.19 Stainless Steel intake valves, 1.88 Inconel exhaust valves and 118cc chamber which a 8.75 to compression ratio.
These engines have dyno time only, were going to be used in my Cigarette but I need new drives more. New Inconel exhaust valves were installed and reassembled with Cometic MLS (Multi-Layer Steel) head gaskets before installing new M1-SC Prochargers. Carbs are Nickerson 850’s and ignition in a combination of Mercury TB IV with custom advance curve and MSD Rev Limiters. They are dynotuned at Victory Engines running 6.5 psi of boost but I will provide 10 psi pulleys and belts with the sale. This setup dynoed at 681 HP @ 5400 using the 6.5 psi setup. Tial BOV’s (Blow Off Valves) and Aeromotive boost referenced fuel pressure regulators included. I also have Aeromotive High Volume fuel pumps I can provide. These are bolt in and go. Price is $19,900 for the pair. I will sell long blocks only for $5500 each or ProCharger setups separately. Call me at 216-244-5479 anytime or email me at [email protected].
Here's the LINK for Pictures....
http://www.flickr.com/photos/motorbi...7627084307349/
