ECM baud rate
I have a 2001 indmar 5.7L TBI engine. Can anyone tell me the baud rate that the ECM communicates at. I realize that Indmar uses there own scan tool but i am trying to communicate with a Snap on scan tool and it would be helpful to know the serial data baud rate. I have been able to get the codes out manually but i would like to look at the data as the boat is running rich
http://www.efi101.com/forum/index.ph...7116bc4785e5be
But typically speaking, basic automotive scanners wil not read a Marine EFI system unless you're trying to build something special.
A good over all marine efi scanner to buy and use is from rinda technologies called the MerCruiser Scan Tool.
http://www.rinda.com/marine/marine.htm
Good luck.
I believe the baud rate is 8192 for MEFI 1-4 computers.
