Change Gears or Props??? >
Old 07-18-2011 | 01:33 PM
Machz1000's Avatar
Default Change Gears or Props???
Trying to figure out if it will be better to change gear ratio from 1.35 to 1.5 and go with a larger pitch prop. Or leave 1.35 and go with a smaller pitch prop.
I was seeing which one would be better for the engine conf and if slip numbers generally get better or worse with a lower or higher pitch.
Machz1000 is offline
Old 07-18-2011 | 02:19 PM
Several very high power boat owners seem to favor either the 1.5 or 1.62 gears. I'm by no means on ya'lls level, but the gear ratio seems to be a better (if more expensive) option
machloosy is offline
Old 07-18-2011 | 04:53 PM
The 1.35's are easier on the drive with a smaller pitch prop but we always end up going back to the 1.50 and bigger prop for the speed.
brian41 is offline
Old 07-18-2011 | 06:27 PM
1 MAIDEN AMERICA's Avatar
A prop person on this site said a good starting point on props is twice the diameter of the prop is a good pitch to run. e.g. 15 5/8" prop w/32 pitch. My boat gets on plane way better with lesser pitched props but I have to run my 1.5:1 lower with a 35P because of coin. Hopefully next year I'll get some 1.36:1 lowers and 32P props for my birthday. I'd love the data comparison.
The only thing I ever hear is that the 1.5's are stronger.
Anyone else do this swap? What'd you gain/loose out of it?
1 MAIDEN AMERICA is offline
Old 07-18-2011 | 07:02 PM
1.36's are actually stronger than 1.5's apparently.
Philm is offline
Old 07-19-2011 | 12:07 AM
I would leave the 1.35's. I don't think you will see any big differences and you won't have to worry about running prop pitch.
A 1.35 change to a 1.5 is usually about a 3" pitch difference.
Griff is online now
Old 07-19-2011 | 01:31 AM
tcelano's Avatar
+1 especially with a cat. In my mind, 1.5:1 is standard gearing on a V and 1:3whatever is a good cat starting point. Unless your speeds are under 80 (guessing thats not the case with any skater...) I wouldn't entertain the 1:5 unless you have motors that really need to rev.
tcelano is offline
Old 07-19-2011 | 08:08 AM
What motors r u running , r u hitting the rev limiters , what size props ?
chuckels is offline
Old 07-19-2011 | 09:17 AM
Machz1000's Avatar
Its on a 32 Skater. Ilmor V-10s. No6's. I changed cams in the engines again and they are making good power up top. The boat pulls like a freight train after about 85mph. Runs good to 120 but then feels like it hits a wall. I have 1.35's in the drive and am turining the props in. They are 16.5 x 35 Merc 4 Blade. Its only turning them 5500rpm @ 120. The cam change and valve train that i have will handle 6500. That is where i set the rev limiters. I just feel like if I change to the 1.5's like Peter at Skater suggested, and run the 35's i think it will get the engines up a little higher in there peak hp.
Old 07-19-2011 | 09:34 AM
Brad Zastrow's Avatar
Here lies the problem. If you go to a 1.5 you will run out prop. The biggest four blade is a 34. You will need to go to five blade prop that the 32 Skater does not like. Been there done that. I did the gear changes on my 32 and I should have stayed with the 1.24. I have a set of 16.5 x 32 four blades I can sell you for $1500. MINT props. Way cheaper than gears changes.
Brad Zastrow is offline
