Procharger crankcase breathing >
Old 07-19-2011 | 08:35 AM
Default Procharger crankcase breathing
just finished my procharged carb HP500, fresh engine, ran last season, maybe 20 hours, have it setup like procharger says 2 valve cover mounted PCV's to the air intake bell, but they do not draw much and have oil pushed out of dipstick...engine builder says not breathing....anybody ran into this ? thanks Rob
ezstriper is offline
Old 07-19-2011 | 09:21 AM
Run two oil filler necks with scotch brite pads rolled up inside. Then mount a breather to the end of them, it works great on mine.
kennyo is offline
Old 07-19-2011 | 09:37 AM
I had the same issue, remove the PCV's on the valve cover outlets, run straight hose, it solved my problem. Having said that, some of my problem was condensation/moisture building up in the oil which raised the oil level, raising crank pressure after a hard run. I brought up the water temp and removed the oil cooler, all seems well now. Good luck with it Rob, nothing like the feel of a Procharger "kicking in".....
FogduckerIII is offline
