454 build questions on cam and carb >
Old 07-19-2011 | 07:13 PM
Default 454 build questions on cam and carb
Im in need of some one to tell me a good size of the cam and carb needed for my build up of the 454 so here is what I have so far
SCAT
crankshaft 4.25
forged I beams 6.135
flat top forged pistons .030 over
9.0-1 compression
cast iron 336781 heads with 2.25I 1.88E
edelbrock rpm air gap
looking for cam size
looking for carb size
this is a gen 6 roller cam block and has stock manifolds and quick silver through hall exhaust
I am now looking in to EMI thunder exhaust after reading the posts can any one tell me if this exhaust will flow good for this set up
any help would be very appreciated thanks guys
mill9876 is offline
Old 07-19-2011 | 07:40 PM
If it's a mark 4 this cam.
http://www.summitracing.com/parts/CRN-139011/
This carb.
http://www.jegs.com/i/Holley/510/0-9...oductId=743728
picklenjim is offline
Old 07-19-2011 | 08:33 PM
One of the biggest factors for a cam is
WHAT exhaust do you have or plan on having?
1BIGJIM is offline
Old 07-19-2011 | 09:38 PM
sorry its a gen6 with a roller cam and im runing stock manifolds with quick silver through hall exhaust on a 1997 baja 202 islander
mill9876 is offline
Old 07-19-2011 | 10:08 PM
With stock Merc exhaust, you are severly limiting the cam choice and ability to make more power. You can really only use slightly more than a stock magnum cam or you will get water reversion.
Griff is offline
Old 07-19-2011 | 11:53 PM
This is the cam for the Gen 6.
http://www.summitracing.com/parts/CRN-168731/
As mentioned exhaust will be a big factor.
Old 07-20-2011 | 03:38 AM
call BOB Medara !!!!!
DareDevil is offline
Old 07-20-2011 | 05:36 AM
I have similar set up with approx .6 lift cam setup...
What horsepower do you think he will see with this setup?
I run a 750 dp holly carb, if i dont ease into the top end it stutters occasionally but thats prop a fuel pump concern..
I had to add 10" pipes welded onto my risers with a stainless marine exhaust bc of reversion.
pantera232 is offline
Old 07-20-2011 | 07:49 PM
looking in to EMI exhaust
mill9876 is offline
Old 07-20-2011 | 09:10 PM
SCAT
crankshaft 4.25
9.0-1 compression
Get the exhaust with long risers.
Your compresion will be lower than 9 to 1, more like 8.7 to 1. I have 8.9 to 1 and I have 489 with flat tops and 110cc chambers. A crane 731 would be good, or get a custom roller from RMbuilder. You may want to use 2.19 valves, you will want to do a good job on bowl blending with bigger valves. Here are the head specs 336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports
jeffswav is offline
