500+ HP 468 bbc NEW!!!!! "0" hours $6500 >
Old 07-19-2011 | 08:13 PM
Default 500+ HP 468 bbc NEW!!!!! "0" hours $6500
just built: test run only. this engine will make well over 500 hp. it needs to be dynod to max it out. (i can have this done for an extra 500 bucks)
-diamond racing pistons
-dimple rods w arp bolts
-std/std steel crank (all balanced)
-isky roller cam/lifters/springs
-reher morrison stud girdles
-plasma moly file fit rings
-clevite H bearings
-rect port heads (2.25int 1.90 exh, milled .060 port matched and bowl cleaned, 7/16 rocker studs, crower roller rockers,)
-port matched / ported weiand intake
-holley 750 dp carb
-9.3:1 comp
-flywheel and balancer included
built by corder performance racing engines in Monticello KY. they are very good at what they do. can be test run prior to buying.
nice engine. mildly built with top quality parts to last for a long time and be reliable. ready to go. call 606 575 0208
2tonchevy is offline
Old 07-19-2011 | 08:39 PM
What lift roller cam?
pantera232 is offline
Old 07-19-2011 | 08:44 PM
.552 int (228 dur) .578 ex. (238 duration)
112 center
