Do all cats lean
Old 07-23-2011 | 11:12 AM
Default Do all cats lean
do all cats lean when you are turning I am just rigging a 15.5 express nitro with a 90hp johnson v4 and I feel like I am gonna tip over when I am turning I just started wet testing the boat but I am wondering for some input from you cat guys I hate feeling like I am gonna tip over do I have too much motor in the water or something or is that just the nature of the beast please help guys
26MartiniMan is offline
Old 07-23-2011 | 11:20 AM
fireboatpilot's Avatar
RIPSTA Racing Team
Forget everything you knew about how a "V" bottom handles, especially in a turn. Take it easy at first, theres a big learning curve to a cat. Water can pile up on the outside in a turn and flip you like in sand or snow if you've ever had the pleasure. More like driving a car in a turn. Head in and power out. Do not abruptly let off the power while turning if you can help it. Build yp your speed as you gain confidence and experiance. I'm not familiar with a single engine cat, especially a single outboard but I'm thinking a cat hul is a cat hull. It takes time, seat time. I'm new to cats myself for about 3 seasons now and learning all the time. I'm sure some others with a lot more exp. than me will chime in soon. Maybe they'll tel me I'm wrong?
fireboatpilot is offline
Old 07-23-2011 | 11:42 AM
Not all cats lean out ,but most do..feels scarier than it is.. Thankfully Skater's lean in or turn flat...
Baja555 is offline
Old 07-23-2011 | 11:49 AM
As speed increases and the tunnel starts to pack air the hull will turn flat or with a slight lean into it.
AO31 is offline
Old 07-23-2011 | 01:11 PM
they are alot of fun when you learn to drive them..just dont in over your head..
Baja555 is offline
Old 07-23-2011 | 01:51 PM
Catastrophe's Avatar
You are not wrong.
Take small careful steps while learning and enjoy !!!
Catastrophe is offline
Old 07-23-2011 | 02:54 PM
Don't forget about your center of gravity. The higher your powerhead the higher your center of gravity is which is not good. I always dropped engine height and trimmed out on my 21 Skaters. My first one in the 80's had a big V8 300 GT Johnson on a jack plate. It was scary as he'll in a turn but I was too young too appreciate how bad. My last one had a Merc 300XS which was not much better. I sold That boat after a couple of month of cleaning out my shorts.
Pay attention to battery and fuel tank size and placement. Keep them low and centered.
See if there is the possibility of a shorter mid section and take it easy!
skate is offline
Old 07-23-2011 | 08:06 PM
My little 13'er does and it takes some getting used to especially in a little boat.
Mr. Demeanor is offline
Old 07-23-2011 | 09:40 PM
Jassman's Avatar
try one of these..and this is for all cats...
www.twintrimusa.com
I just put one on a 27 Ameracat.. works awesome..controls load or when people move around when under way.....
watch the video's..
Attached Thumbnails Do all cats lean-ameracat-001.jpg   Do all cats lean-ameracat-005.jpg
Jassman is offline
Old 07-24-2011 | 02:27 PM
My old 39' express cat. would lean out too. coming from a V that was scarry! Not as bad as finding out you should never pull back on the thottles in a turn. that thing would spin out like you were driving on snow! Like they said, slow down a little before the turn and hold that speed or even give it a little more in the turn. Power it through, never let out till your straight. Good luck, it's a fun learnign curve!
boot is offline
