portable ac units.
Old 07-23-2011 | 01:55 PM
Default portable ac units.
Looking at a few mid 30' boats with decent overnighter cabins but they are lacking ac. For the few times a year we would overnight , it would be at powered slips. Can you use the small , somewhat portable ac units I have seen online for residential use or are there other portable options?
smoker62 is offline
Old 07-23-2011 | 02:21 PM
Default Fixx
thease work decent..
http://www.kooleraire.com/
FIXX is offline
Old 07-23-2011 | 06:48 PM
I dont know who makes them but there are portable/temp a/c units that sit on the deck thru the deck hatch. Blow in the cabin and vent thru the outside. Great idea.
ActiveFun is offline
Old 07-23-2011 | 07:16 PM
bcfountain's Avatar
Registered User
cruiseair makes carryon a/c units.i have one.it is 4800btu.my cabin is small,but this thing rocks,at times i have to turn it off.i think air to air a/c units give you a better temp change,but on board a/c units are a whole lot more conveient.the guy i got this a/c unit from used it on his 357 foumula and cool great.
bcfountain is offline
Old 07-23-2011 | 07:28 PM
Strip Poker 388's Avatar
Rob
I have a 5kbtu I used it a few times on my Hustler,works good,a 1850 coleman prot gen will run it good also,beoch putting on the deck.you can find them cheap used,My buddy likes borrowing mine all the time,I found him one a craigslist for 250 and told him about it,he wouldnt buy it.Typical
it does make water and runs off the deck.
cruisair carry on air conditioner
Strip Poker 388 is offline
Old 07-23-2011 | 09:48 PM
I have a Velocity 260, so the cabin is not terribly big. I overnight only a couple of times a year, I might try one of thoses $40.00 units. Seems like a decent idea and may work well in a smaller cabin. Worst case, out 40 bucks and a couple of bags of ice....
low_psi is offline
Old 07-24-2011 | 12:25 PM
Default ac
I saw one at homedepot 30" tall 18" portable cooles 400 sq. foot i have a 38 baja going to try it price 230.00 runs 0n 110 volt discharge are will go out hatch window going to make a plate with a 4" hole
riverboater is offline
Old 07-24-2011 | 12:56 PM
i read somewhere,,someone just left the window a/c unit on the dock pluged in,,,and just ran a hose blowing the cold air inside,,,he could use the hatch or the door for the hose,,
TWIN-SPINS is offline
Old 07-24-2011 | 03:17 PM
http://swampy.net/
sonic is offline
Old 07-24-2011 | 06:17 PM
A few friends of mine just use the small home window a/c units.
Griff is offline
