1991 Baja 240ES >
1991 Baja 240ES
1991 Baja 240ES
Old 07-23-2011 | 08:10 PM
Default maybe 1991 Baja 240ES???
I just purchased a 1991 Baja, advertised as a 240ES. All pictures I have viewed of this model of Baja online show an integrated fiberglass swim platform. I have a aluminum bolt on platform just like an outlaw. I am wondering where i can go to identify this boat? Also wondering where the numbers are located on the hull to identify it? Any information would be appreciated. Thank you
kawzracn442 is offline
Old 07-24-2011 | 08:14 AM
i thought from '90 on they had intergrated platforms?? mines a '91 and its intergrated. are you sure you have a '91?? look at your hull ID number on the outside of the transom, the last 2 digits would be your model year
gsxr1216 is offline
Old 07-24-2011 | 09:38 AM
Ok, does the hull ID number start with 0D? If so it is 0D484298. Is there a way to break this number down like a auto VIN number? I was also told the engine is different. The tag by the starter and the carburetor cover numbers do not match. I'm pretty sure it is a newer engine but was wanting to get the details on it, horsepower, year, that kind of thing.
Old 07-24-2011 | 10:38 AM
wow thats a weird ID # on yours??
both of my baja's the last 2 digits matched the model year #
the tag by the starter will probly give you the most info, and usually theres a paper type tag on the top of the bell housing, those sets of #'s would get you the most info about your motor if its still stock
gsxr1216 is offline
Old 07-24-2011 | 10:54 AM
jfm
Baja's start AGC......
jfm is offline
Old 07-24-2011 | 12:36 PM
yes both of mine started with AGC also.
gsxr1216 is offline
Old 07-25-2011 | 07:08 AM
OD484298 is your outdrive serial number.
firehill19 is offline
Old 07-25-2011 | 10:05 AM
Custom Interiors & More
More than likely you have a 240 Sport from 88', or a early Outlaw that was introduced in 92'. Both models were built from the same molds.
Attached Thumbnails 1991 Baja 240ES-88-sport-240.jpg   1991 Baja 240ES-94_95_outlaw.jpg
XT-Innovator is offline
