Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
help with muddy water stains.. >
Old 07-24-2011 | 07:18 PM
Default help with muddy water stains..
I have a white hull boat, and we boat in some muddy water, and its stained the bottom of the boat, a brownish color. Is there anything out there that I can remove the stains on the bottom on the boat.
stlliberator is offline
Old 07-24-2011 | 07:35 PM
Power 1 from Fountain of Youth works good. Also know guys who use toilet bowl cleaner or muriatic acid.
hotjava66 is offline
Old 07-24-2011 | 10:05 PM
Default Fixx
+1 on the toilet bowl cleaner,,the WOKX brand works the best,,buy a few bottles and dump them in a pump sprayer and go to town,,almost works instantly..
FIXX is offline
Old 08-03-2011 | 08:07 PM
power 1 works great, its a little less harsh on the skin than toilet bowl cleaner. both will do the job for you.
1fastlx is offline
Old 08-03-2011 | 08:24 PM
I picked up a blue gel product called FRS (fiberglass restoration "something") from West Marine on the recommendation of the sales guy. I could not believe how incredible it was. Wipe it on and let it sit a few minutes, then rinse off. Within 30 secs, you can see the brown/yellow turning white. I thought it was just 26 years of old and could never be white. I was wrong. That stuff was amazing!
242LS is offline
Old 08-03-2011 | 08:25 PM
BTW - the picture of my boat out of the water was pre-FRS in July. It is white now!
242LS is offline
Old 08-03-2011 | 10:37 PM
I checked - got the name wrong. It is Davis FSR (Fiberglass Stain Remover)
242LS is offline
Old 08-04-2011 | 06:28 PM
wayne272's Avatar
I use stuff called Iron Out from home depot. Put some in a garden sprayer, add water and just spray it on. Stains just disappear then rinse with water.
wayne272 is offline
Old 08-04-2011 | 08:37 PM
I have and use Hula Hull Cleaner. It is non acidic biodegradable and can be diluted. Mixes up to 4:1 goes in a sprayer, sprayed on and wiped or rinsed off after 30-45 seconds of dwell time. Can also be used to remove water spots from fiberglass, windscreens and brightwork.
Hula Boat Care is offline
Old 08-05-2011 | 06:58 AM
Default hull cleaner
from West Marine ...NO AND OFF Spray on and rinse off ....it works awesome
ridefast77 is offline
