Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Outboard transom repair?? >
Old 07-25-2011 | 06:10 PM
Default Outboard transom repair??
Since I have an OB boat I'm assuming the transom replacement ill be a pain in the azz. Besides having the wells to deal with, I also will need to add knees. Attached are 2 pics to help understand what I mean. Its pouring here so no specific pics of transom.
Question is, should I cut the last 6" of deck, just enough to dig it from the top, the whole well of do it from the outside? Thanks in advance, George
prostock85 is offline
Old 07-25-2011 | 09:04 PM
If you don't want to take the entire deck off, I'd cut it where it's smallest, where the area to repair is minimized. Probally at where the corners of the rear seat would be, removing that section, giving you enough room to work.
kb5050 is offline
Old 07-26-2011 | 06:55 AM
rchevelle71's Avatar
Agreed,
That is how I did mine, made the job much easier to work upright vs. laying in the bilge doing glasswork.
rchevelle71 is offline
Old 07-27-2011 | 05:53 AM
Should I cut the deck on a 45 or straight? Or is it soo thin that it doesn't actually matter? Plan on getting it done after work.
Old 07-27-2011 | 07:16 AM
Did mine on a 45, Been running it hard for a year now, and no stresscracks in that area. Make sure you cut it in an area that you can access the backside well when you glass it back together.
Old 07-28-2011 | 10:22 AM
I replaced stringers by cutting off the very top with a sawzall, then used an electric chain saw to remove the remaining wood down to the bottom on the boat. The epoxied plywood slid in perfectly. I seen a youtube video doing the same for an outboard transom repair, but they just filled up the transom with epoxie without any wood.
tbanzer is offline
Old 08-02-2011 | 10:25 AM
Too Stroked's Avatar
Man, I'd have a tough time trusting that repair. The true strength comes from fibers (plywood, Balsacore, glass mat, Penske board, etc.) held together by a resin. I'd be willing to bet that an all expoxy resin transom would be pretty flexible - and that's not what you want.
Too Stroked is offline
Old 08-03-2011 | 07:37 AM
This was a low hp boat using all epoxy for the repair. The existing outer and inner fiberglass was sound so im sure the repair was way better than the strength of the transom that was in service the day before. My main point was there are other options for repairs in situations where only the wood was rotted and replacing a sound glass shell or refinishing the outer gel can be avoided. Might not apply here for the transom but may apply somewhere else in this project.
tbanzer is offline
Old 08-03-2011 | 11:06 AM
Ah, now I feel a little bit better. For a 9.9 HP on a blow boat or something, that might work. Call me silly, but I get kind of picky on construction - particularly on an outboard transom. I really hate it when I whack the throttle and the transom - with outboard attached - passes me by.
