502 mag weird starting issue >
Old 07-27-2011 | 07:48 AM
Default 502 mag weird starting issue
on my 96 502 mag it will crank and not start or fart or anything but if i spray some gas into the intake the engine will start and continue to run and i can drive it fine until i shut it off. it does this cold or hot
thanks
neil
Yoda_Man is offline
Old 07-27-2011 | 09:18 AM
Might be time for a new fuel pump.
TexomaPowerboater is offline
Old 07-27-2011 | 10:47 AM
Fuel pump or it might be drawing air around a fuel fitting which won't let it prime up. I had the same issue with a motor in the boat except it would run on the gas that was poured in the carb and then cut off. Once I redid all the fuel fittings no more issues.
cdail28590 is offline
Old 07-28-2011 | 10:26 AM
thanks guys for the replies turns out it was the fusable link that supplies the computer power from the starter. it was broken so i guess with the added voltage drop while cranking the bad connection was giving the computer too low of a voltage.
Yoda_Man is offline
Old 07-28-2011 | 08:52 PM
at least it was a easy fix
firehawkcat is offline
Old 07-29-2011 | 05:27 AM
Nice.
how did you track that down?
tlracer1 is offline
