Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Removing tabbing, glass?? >
Old 07-27-2011 | 10:28 PM
Default Removing tabbing, glass??
What tools do you guys use to remove the glassed in tabs and main inner fiberglass of the boat? I have a 4" grinder and 7" buffer/grinder. Ive only been using the 4" with a metal grinding disk as well as a cut off disk. Should I use the 7" with a sanding disk? Thanks in advance for help, I'm still learning.
prostock85 is offline
Old 08-04-2011 | 07:12 PM
Default Fixx
you should be using 36 grit grinding disc's, the meyal ones seem to just melt everything and tales too long to get any where..
FIXX is offline
Old 08-04-2011 | 08:28 PM
I ended up buying a few 16, 24 and 36 grit for use on the variable speed buffer. Seems to have made the job go twice as fast as well as making the transitions smoother. Thanks for the reply.
George
Old 08-08-2011 | 11:43 AM
http://www.amazon.com/PFERD-67343-PO...1184463&sr=8-1
ebendrey is offline
Old 08-09-2011 | 07:13 AM
Audiofn's Avatar
Charter Member #232
If you have a LOT to remove then you can use a power planer.
Put your best foot forward!
Audiofn is offline
