Gen IV BBC Parts; oil pan, main caps, TC, balancer, mounts etc
Hello,
I have the following MK IV stuff:
set of 4 bolt main caps GM: $50
Gen IV timing cover: $20
8" Balancer: $50
Steel Mercruiser marine oil pan, dipstick, pump and pickup: $80
Standard Flywheel: $60
Motor mounts engine side: $40 per pair (have 4 pair)
Solid motor mounts Merc Stud Style Billet Al: $100 for 2 pair
Circ pumps good used: $40 each
T stat housings good used $40 each
Bravo HP couplers: $325 for the pair
Remote oil filter mount and lines: $40
Let me know what you need.
Thanks,
Brad Harbold
8" Balancer: $50
Thanks,
Brad Harbold
I need remote oil filter bracket and hoses for 502 Gen V ASAP.
Is yours this style?
http://m.bismanonline.com/mercruser_...photoId=601523
Also have the bypass valve assembly that goes on the block for a Gen IV BBC: $40
Have a pair of good used starters too for BBC $150 for the pair
Have another small oil & power steeirng combo cooler good used, stock Merc 330 style. $40
Have a pair of Merc fuel filter/water seperator heads with fittings. $30
Have pair of annodes for TRS or possibly others with skeg good shape $10
Latham Marine TRS Wing plate for hydraulic steering: $20
Pair of good used TRS upper main shafts $80 for the pair, may also fit other SSM drives
