Mercury Hp 500 power steering pump >
Old 07-29-2011 | 05:00 PM
Default Mercury Hp 500 power steering pump
Mercury Hp 500 power steering pump looking for a part # or replacement if someones got one avail .
thanks in advance
fountainfan42 is offline
Old 07-29-2011 | 09:13 PM
what happened? just got done welding the resivoir on mine after the studs in the back brok and it turned sideways.
endeavor1 is offline
Old 07-31-2011 | 02:51 PM
shaft was loose as a goose
Old 07-31-2011 | 05:34 PM
SCRAPMAN1's Avatar
you may be able to save some $ compare your old pump to just about any GM rear wheel drive pump from the mid to late 90s and you should find a match. I replaced a bad one on my 850 with a unit from a 98 chev van- cannister was a little different but we adapted it easily
SCRAPMAN1 is offline
Old 08-18-2011 | 09:26 PM
thanks worked just as mentioned
Old 08-18-2011 | 11:26 PM
Just curious, what was the part #. Mine is ok now but for future reference.
