496 HO Belt Squeal >
496 HO Belt Squeal
496 HO Belt Squeal
Old 06-05-2002 | 02:50 PM
Frequency's Avatar
Question 496 HO Belt Squeal
Squeal, Squeak, Whine ...whatever. That's what I'm hearing from my new motor. More pronounced at higher rpms, the sound comes through the engine box. Only 2 hours on the engine. Has anyone else ran into this????
Frequency is offline
Old 06-05-2002 | 03:03 PM
CigDaze's Avatar
120 hours here and not one sound from the belt. I would suspect that there is some kind of pulley misalignment going on with your set-up. That could really degregate the life of your belt.
CigDaze is offline
Old 06-06-2002 | 09:08 AM
JGB's Avatar
JGB
i have 496 mags andI had something similar that i thought was the belt. it ended being the air being sucked into the air filter/flame arrestor at about 2500 rpms and then stopped in the low 3000s rpm. A reccomendation i got for this was replacing the stock air filters with K&N brand. i haven't done it yet but it is on my list of things to do.
if you do it. let us know if it worked!
good luck
JGB is offline
Old 06-06-2002 | 10:58 AM
Frequency's Avatar
Thumbs up
I'm taking the boat out for a few hours today - I'll check it out at those rpm's, and inspect the belt to see if it's showing signs of wear. Thanks guys...
Old 06-07-2002 | 09:39 AM
Frequency's Avatar
Lightbulb
Yup, the 496 HO sucks - AIR. At idle, the belt drive makes that "scrunchy" sound which suggested it might squeal at higher speeds. A few runs with the motor box open proved that was not the case. It's definitely the flame arrestor. Good news is, the noise bothers my wife, so she may insist on the K&N fix.
Old 06-07-2002 | 06:10 PM
JGB's Avatar
JGB
let us know if it works for you!
good luck
JGB is offline
Old 06-15-2002 | 04:53 PM
JGB's Avatar
JGB
any luck with K&N flame arrestrs?
JGB is offline
Old 06-15-2002 | 10:06 PM
ROUGHSTUFF
I have never used K&N filters, any truth that they help airflow and give a bump in HP and better MPG??
Old 06-16-2002 | 08:16 AM
78 hours and no noise at any speed
Vyper340 is offline
Old 06-16-2002 | 08:45 AM
BillR's Avatar
OSO Moderator
496's will not gain any more power or speed from a K&N, the stock flame arrestor flows real good. Now you WILL get clean air in the motor. All the belt dust will be caught in the filter vs. ingested in your motor.
BTW: My belts never squeeked, but DO throw alot of dust. Even after 62 hours.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
fountain27ho496
07-15-2008 09:35 AM
JohnnyG
2
07-06-2007 12:54 AM
bozsage
2
06-12-2007 06:58 PM
Shooter
4
11-09-2006 08:55 PM
davis777
0
02-01-2006 12:27 PM
