broken bearing/bracket inside ITS >
Old 08-01-2011 | 08:56 PM
Default broken bearing/bracket inside ITS
Hello,
I have a 2001 36 foot baja outlaw with twin 496, 500 horsepower with ITS factory mercury setbacks. After removing bottom inspection plate we can see a cracked bracket and failed bearing. Can I remove the setback boxes without pulling the motor (support motor and remove or will brackets or will motor stay in place if box is removed?) Does anyone know where I can get a schematic blow up or parts list for this integrated transom system setbacks? My serial number on my bravo outdrive is 0m231804 and there is a mercruiser smartcraft sticker. Thanks so much for any help anyone can provide.
~James
jmatarozzo is offline
Old 08-01-2011 | 09:02 PM
Sydwayz's Avatar
Forum Regulator
www.bammarine.com will have all the parts diagrams that you need.
Sydwayz is offline
Old 08-01-2011 | 09:17 PM
couldn't find any parts diagrams
Old 08-01-2011 | 09:26 PM
Sydwayz's Avatar
Forum Regulator
http://www.mercruiserparts.com/selec...sp?type_id=DRB
Sydwayz is offline
Old 08-01-2011 | 10:52 PM
Thank you for your help. Unfortunately, I am unable to find exactly what I'm looking for.
Old 08-02-2011 | 05:28 AM
Mbam's Avatar
Offshoreonly Advertiser
Here you go
http://www.mercruiserparts.com/selec..._nbr=891749001
Mbam is offline
