454 carb fuel mixture >
Old 08-02-2011 | 06:59 AM
Default 454 carb fuel mixture
How do you adjust the fuel mixtire on the weber carb? Or more importanly what should the factory specs be. Both the front 2 screws are set at 1 and a half turns but unsure if there are any other things to check/set as well. Seemed to be running a little light on the plugs
kragar is offline
