502 Stroked to 547 - Oil Cooler Suggestions
I have a 502 that has been stroked to a 547, the current Mercruiser oil cooler doesn't look sufficient, and my mechanic thinks that may have been part of the problem with the last blow up. Any suggestions?
This is what I currently have...
Teague has some very well priced oil coolers that will work. I bought a 3X18 from them for my stock 502 because I was going to bump it up to 500HP eventually. Hard part is finding were to put it, but there are a couple of people making the clamps that bolt on to the bell housing.
http://www.cpperformance.com/p-13617...il-cooler.aspx
This is the same brand but cheaper price
http://www.mrcool.us/mrc-cph-650.html
If you have stock oiling system, remove it all NOW, block adapter, filter mount, lines, useless now...make sure you have a 30psi relief in the block, use a good block adapter, canton etc that used 1/2 fittings, a good 3"x18" cooler(eddie marine has a nice one, oil filter adapter, canton/moroso and #10 lines as short as you can get them....old stuff from merc is junk for anything above stock...
