front galley bildge pump - black box? >
Old 08-07-2011 | 11:13 PM
Default front galley bildge pump - black box?
My front bildge pump ran the battery completely dead while being stored..... after charging the batter for a while, I could hear some clicking coming from the floor board. . . . And its coming from the black box. There's no water anywhere in the boat .. .. this black box was clicking like nuts. ... on and off really fast, then to a solid on full time, even after the mast power is off. Batter had to be fully disconnected before it would quit.
Is this a level float control?
EDIT: This is located in the first step into the cabin area. The black box has a constant hot 12v sorce wire, there's no switch to the dash, and there's no light to indicate that it's running.
http://i122.photobucket.com/albums/o...-44-47_479.jpg
TooTall is offline
Old 08-08-2011 | 01:55 AM
yes, looks like a water sensor. Do you have a switch on your dash to turn that bilge on manually? Looks wired to be either auto or manual mode or sends a signal to a light on your dash sayings its on?
triple 300s is offline
Old 08-08-2011 | 06:35 AM
Its a water sensor that seems to fail a lot.
That bilge pump doesn't have a switch on the dash. On my 32 there isn't even a spare. On my list to do when I get back to working on the boat.
Wildman_grafix is offline
Old 08-08-2011 | 09:28 AM
Where is the front bilge pump located and how do I get to it on my 35 Lightning, thanks for any info.
253 is offline
Old 08-08-2011 | 09:31 AM
blownincome's Avatar
Under The Step In The Cabin
blownincome is offline
Old 08-08-2011 | 09:36 AM
has anyone replaced theirs, or did you use some other after market float switch?
if you did, is there a part number for the orginal?
if you used an after market one, what did you go with, or did you use/add another switch on the dash
TooTall is offline
Old 08-08-2011 | 09:37 AM
it would be easy to just install a float switch in there. Rough and area up and get some 5200. I am not sure what the 3rd wire is going to though?
Old 08-08-2011 | 11:02 AM
(3 WIRES) Power And Ground To The Electronic Float Sw And Power From The Sw/side of the switch To The Pump. Yes You Can Install And Standard Float Sw To Replace The Electronic One.
