Go Back  Offshoreonly.com > Owners Forum > Powerquest
1999 280 nav light? ???? >
Old 08-08-2011 | 04:49 PM
Default 1999 280 nav light? ????
K so i have the 99 280,silencer. An my front nav light only works when it wants to. Anyone els having this problem? All other lights work great. Any advice.
dra200832 is offline
Old 08-08-2011 | 08:29 PM
take the light bulb out and clean the corrosion and apply a little dielectric grease on the contact points.
boatnt is offline
Old 08-09-2011 | 02:57 PM
X2. Had that same issue with my 340.
diggin H20 is offline
Old 08-10-2011 | 01:59 AM
Ok ill give it a shot tonight. If there r antother ideas let me no
Old 08-17-2011 | 12:43 AM
Is there a connection eith in the nose cone of the boat.
Old 08-17-2011 | 08:40 PM
If you remove the panel in the forward v-berth you can get to the wiring. I believe it is just crimped in.
Old 08-17-2011 | 08:50 PM
I doubt you have a connection problem to the light. it is probably the contacts in the housing itself most likely the contacts that touch the bulb.
specialk is offline
Old 08-23-2011 | 06:55 AM
It was in the contact clip its self. Chep fix just cost alittle to find do to my impatints
