Aeromotive A1000 sounds like war!
Hi i have two Aeromotive A1000 red fuel pumps who i have used for about 40 houers, the fuel pumps sounds like **** like they are gona be ten years old, and there are no water in the pumps i have water sepparators before the pumps!
Are this normal for thus pumps? if so its **** pumps!!!!
Sweden
Sweden
If these pumps are run with the slightest bit of air aerated with the fuel it will tear them up almost immediately. As with all geroter or vane pumps they should only be fed from a sump on the bottom of the tank. Not pulled from a drop tube bolted to the top of the tank. Also make sure the pumps are always mounted below the fuel level of the tank at all times regardless of whether they are fed from a sump or not. They are rebuildable.
Mount them below the bottom of the tank, in most applications you can get them in the deepest part of the bilge. Put them as close to the tank as possible.
