gen 4 heads on gen 6 block can i us stock rockers and push rod >
Old 08-10-2011 | 06:33 PM
Default gen 4 heads on gen 6 block can i us stock rockers and push rod
Im puting 871 head from gen4 on my gen6 and im wondeering if i can us my stock rockers and push rod thanks any help is appreciated
mill9876 is offline
Old 08-10-2011 | 10:09 PM
Maybe, when you start assembley be sure to check out the geometry. I'm not sure but, you may have pushrod clearance issues and require grinding. Not 100% sure though
mr3dman is offline
Old 08-10-2011 | 10:15 PM
Never Never Never assume that a given push rod will work in your valvetrain.
Always Always Always measure twice and buy once (or use what matches what dimension for intake and exhaust) for the correcto mundo push rod for YOUR motor/valvetrain combo.
Hmmmm sounds like a carpenter rule.
ROTAX454 is offline
