496mag HO problem >
496mag HO problem
496mag HO problem
Old 08-14-2011 | 05:05 PM
Default 496mag HO problem
I was running my '07 Velocity with 496mag HO. Everything was fine until my alarm went off. The motor still ran after the alarm went off and nothing seemed wrong. I've checked all the fluids and everything seems fine. What else could the problem be, or do I have to have the motor scanned? It only has 30 hours on it.
velocityvw is offline
Old 08-14-2011 | 08:49 PM
Scan that sucker, thats the problem with computers could be 50 different things but the scan will narrow it down for sure, hopefully it is something simple and cheap
firehawkcat is offline
Old 08-14-2011 | 08:56 PM
Dave M's Avatar
Veteran: Navy
Yes, get it scanned. Was it a steady beeeeeeeeeeep, or a series of beep beep.......................................beep beep?
Dave M is offline
Old 08-15-2011 | 12:00 PM
If all gauges are reading correct with the alarm going off check the drive oil res. Small plastic bottle with black cap. May have low drive oil or the connection for the sensor may have come loose.
4bus is offline
Old 08-15-2011 | 09:01 PM
could be sea water pump..... mine would only go off above 3500 and return to idle and it would quit sounding
gotstreetracin is offline
Old 08-21-2011 | 07:03 PM
Thank you very much for the advice. It turned out to be the impeller beginning to disintegrate. I appreciate the help!
