Cam Specs for a 525 EFI >
Old 08-14-2011 | 08:42 PM
Default Cam Specs for a 525 EFI
What are the cam specs for Merc's 525 EFI
Advantage 575 is offline
Old 08-14-2011 | 09:25 PM
Crane 16HR00004 BBC Hydraulic Roller
Duration (advertised) - 298/306
Duration (@ 0.050) - 234/244
Lift - .610 Intake, .632 Exhaust
Lobe Center - 114°
bsboss is offline
Old 08-15-2011 | 12:23 AM
I have everything else the same except I have the duration at .050 as 236/244, not 234/244.
Eddie
Young Performance is offline
Old 08-15-2011 | 01:49 AM
Its a Crane 168741 except ground on a 114 lob sep.
http://www.cranecams.com/product/car...detail&p=24283
Griff is offline
Old 08-15-2011 | 11:40 AM
Eddie
What max HP can you expect with this cam in a 540 with a 871 blower. Compression is 8.5 and it is fuel injected
Old 08-15-2011 | 12:07 PM
Fenderjack's Avatar
Pirate of the Chesapeake
That thing will like boost
John jr
Fenderjack is offline
Old 08-15-2011 | 01:13 PM
Do you have an intercooler?
Old 08-15-2011 | 01:53 PM
If you have a choice I'd put the Crane XXX651 cam in.
kvogt is offline
Old 08-15-2011 | 07:35 PM
Yes whipple MOAC. Cam is a COMP .610 INT, .637 EX 242/248 @ 50. CMI E-tops, DART 325 CC Pro 1's.
Old 08-16-2011 | 09:54 AM
You have an easy 800+ hp setup, depending on boost. How mush are you looking for?
