Any truth to a triple digit AT????? >
Old 06-06-2002 | 06:33 PM
ssherman
Default Any truth to a triple digit AT?????
I heard those 5 blade hydromotives are bad boys.
Old 06-06-2002 | 06:43 PM
birdog's Avatar
Wouldnt they be even tougher on drives than the 4 blades ?
birdog is offline
Old 06-06-2002 | 07:20 PM
Tejas Raz
Ditto,
Which one? What power? Can I borrow it?
Old 06-06-2002 | 07:29 PM
BlueMoon
Last I heard, a correct prop setup was VERY important to top speed and performance.
Old 06-06-2002 | 07:42 PM
KAAMA's Avatar
Birdog, I would also like to know the answer to the question you asked about the 5-bladed props being tougher on an outdrive.
KAAMA is offline
Old 06-06-2002 | 08:25 PM
Ted G's Avatar
If we use a car analogy then yes 5 blade props would be harder on the drives.
When you put slicks on a car and it begins to hook up hard to the road you begin finding where your driveline parts are weak.
Since 5 blades have more "bite"(traction) they will put more pressure on the driveline-especially the drive(s).
www.cbpba.com
Ted G is offline
Old 06-06-2002 | 08:42 PM
birdog's Avatar
Yep.....Thats what got me thinking. Maybe 3 blades wouldnt brake these Bravos so much?
birdog is offline
Old 06-06-2002 | 11:54 PM
KAAMA's Avatar
That's what I suspected as well---I'm running on the edge now as it is with my XR's and 704lbs of torque. I think I'll stick with the 4-bladed props for now.
KAAMA is offline
Old 06-07-2002 | 12:02 AM
26scarab's Avatar
Jesse James,
I don't think the 6's are the fix all type of answer. Maybe for you guys with big boats it is but I think a 26 Scarab with a 6 hanging off of the back might just sink !!
I've been lucky so far though ,675hp thru a stock Bravo with a total of 200 stock motor hours made it thru 2 poker runs and about 35 hard hours.
I will be trying my XR soon so hopefully that will be good enough for me.
And I agree about the throttle arm does allot of the breaking . The splines on my prop shaft are still perfectly straight ! Guess I'm okay !
26scarab is offline
Old 06-07-2002 | 01:45 AM
eliminator219's Avatar
Default Stock Bravos
26 scarab
200 hours with stock drives and 675 hp, what about broken parts? Many? You really deserve a pat on the back for that!!What made you change drives, getting scared or are you adding hp?anyway, good going just wish that I can have that kind of luck! or skill
eliminator219
eliminator219 is offline
