The Famous HORN LEAK!! >
Old 08-15-2011 | 09:10 AM
Default The Famous HORN LEAK!!
So ive heard baja had a shortage of caulk/silicon while putting the horns on !! Anyhow i have a huge leak coming from both horns on my Vberth!
Any ideas on how to fix? is the "Grill Cover" Easy to remove so i can see whats going on?????
Should i replace the horns? Any Info WOuld Be VERY HELPFUL!! let me know thanks!
USaveOnTime.Com is offline
Old 08-15-2011 | 09:26 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
The grill cover pops right off. Two screws to get the horn out. Very simple.
Baja_342 is offline
Old 08-16-2011 | 10:28 PM
Smitty's Avatar
Your front cleats are another source of a leak. Put a hose up near the windshield/fairing and let it run down the deck while you lay up in the front and see where the water is getting in.
Smitty is offline
