Knocking sound when cranking >
Old 08-15-2011 | 01:29 PM
Default Knocking sound when cranking
What would make it? It almost sounds like a rod knock but it is before it starts and while cranking. Engine runs fine and it has only done it a few times. Starter maybe? If I can get a video with the sound I will post up.
DirtyJohnson is offline
Old 08-16-2011 | 11:22 AM
blue thunder's Avatar
My guess would be slight hydro lock of the engine which the starter is able to overcome. Your exhaust may be leaking water into the engine while sitting.
blue thunder is offline
Old 08-17-2011 | 08:00 AM
It could be rod knock, happening before the engine builds oil pressure. Had an old jeep that would do that, until it finally spun some bearings.
Philm is offline
Old 08-17-2011 | 07:59 PM
Check the easy stuff … I had a couple of loose bolts on the idler pulley that sounded exactly like a rod nock.
PremierPOWER is offline
Old 08-17-2011 | 08:02 PM
Agreed check the easy stuff 800 ponies could rattle stuff loose
firehawkcat is offline
Old 08-18-2011 | 10:55 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Had a WP pulley knock while cranking. Loose screws. When running sounded fine.
US1 Fountain is offline
Old 08-18-2011 | 09:46 PM
Yes look at all rotating parts on the front. Then check starter and could have a cracked flex plate good luck!!!!
skydog is offline
