A few teasers :D Getting close
Pirate of the Chesapeake
Have been making progress on the boat.. Dad has been doing a bit of fitting, last week we got the holes cut for the tabs.. Pics are of the engine, all we need is the carb, some sending units, finish fabbing the tensioner bracket for the blower.. Box is on, looks pretty impressive i must say.. More pics to follow, as we should have the transom buttoned up in a short..
John jr
John jr
No believe it or now were running a alpha 1 gen 1 with a 30 4 blade bravo. We are going to use it again. The boat is light,and the engine does not have the torque of a big block>It has held up well with 350 HP going thru it,got to watch when you leave the water and re-enter,and No Hole shots so we will see.If not we might go to a bravo 1 or a blackhawk converted to single prop.JOHN SR
If that is a PCV valve on the left cover I suggest removing it before install......I had nothing but problems with my oil pressure with a similar set-up with the Procharger and once I removed the PCV and ran a straight open hose it solved the problem, good luck with the install.....
