Difference between the BravoX and XR? >
Old 08-17-2011 | 12:47 PM
Default Difference between the BravoX and XR?
Can you tell by just looking at the drive the difference between an X and XR drive?
And in what year did the swept back style Bravo come out?
grads2112 is offline
Old 08-17-2011 | 12:51 PM
wrinkleface's Avatar
by the sticker on it???? 06 I believe!
wrinkleface is offline
Old 08-17-2011 | 12:54 PM
That is my concern, that someone could just change the stickers.
Old 08-17-2011 | 12:58 PM
Dave M's Avatar
Veteran: Navy
You can probably tell by the serial number.
Dave M is offline
Old 08-17-2011 | 01:02 PM
Can you elaborate on that. What should the numbers be with an X or XR?
Old 08-17-2011 | 01:07 PM
BrettM's Avatar
Offshoreonly Advertiser
Commercial Members
Spiral cut gear in the X and small prop shafts
Diamond cut and large prop shafts in the XR
Plus different cases and carriers and such. Basically lots of differences.
You can tell immediately by the prop shaft size.
BrettM is offline
Old 08-17-2011 | 01:20 PM
Dave M's Avatar
Veteran: Navy
Here's some info here.
http://www.offshoreonly.com/forums/g...er-lookup.html
Dave M is offline
Old 08-17-2011 | 03:38 PM
My 05 370ss has sweptback XR's
redbud35 is offline
Old 08-17-2011 | 04:03 PM
Sweptback is from late '05, according to my merc pusher.
A.O. Razor is offline
Old 08-17-2011 | 04:12 PM
Gladhe8er's Avatar
The prop shaft is the give-away....however, somebody could have bolted an XR lower to an X upper and replaced the X sticker with XR stickers. Seems like a lot of work to go though...
Gladhe8er is offline
