496 mag buzzer / alarm
Old 08-18-2011 | 02:31 PM
Default 496 mag buzzer / alarm
I just changed my impeller, when i first launch the boat after a few min at idle the alarm will sound, temp is fine so I put it in gear to go fwd slow and alarm goes off. does antone have a clue
RICK8SOS is offline
Old 08-18-2011 | 03:46 PM
Gladhe8er's Avatar
It could be one of the many sensors on the motor. Get it scanned and it should give you the culprit.
Gladhe8er is offline
Old 08-18-2011 | 04:51 PM
Check drive lube reservoir. Low level will trigger alarm.
DLEWIS1340 is offline
Old 08-18-2011 | 06:08 PM
noyzee's Avatar
my drive res was making mine go off and it was full. i unpluged it and boom it went off. so i replaced it.
noyzee is offline
