496 mag buzzer / alarm >
Old 08-18-2011 | 02:47 PM
Default 496 mag buzzer / alarm
Help! I changed the impeller and on my last two times out I got an alarm at idle, once in gear alarm went off for remander of the day. can anyone explain?
RICK8SOS is offline
Old 08-18-2011 | 03:10 PM
Default Fixx
replace the water pressure sensor,,common problem with the 496..
FIXX is offline
Old 08-18-2011 | 03:13 PM
Do you know how much the sensor cost
RICK8SOS is offline
Old 08-18-2011 | 03:22 PM
Default fixx
from bam 102.00
# 10 in rhw pic
http://www.mercruiserparts.com/Show_...=SEAWATER+PUMP
FIXX is offline
Old 08-18-2011 | 03:27 PM
Should I trouble shoot it first before buying one? Maybe disconnect it to se if thats the alarm or not?
RICK8SOS is offline
Old 08-18-2011 | 03:41 PM
Just bit the bullet and buy it. I spent half of last summer dealing with the same issue. Turns out I had a few grains of sand plugging up my water pressure sensor. It is an easy fix. It is located on your Impeller Housing.
low_psi is offline
Old 08-18-2011 | 03:46 PM
Thats a $100 bullet buys alot of Beer
RICK8SOS is offline
Old 08-18-2011 | 04:28 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Have it scanned by a mechanics or buy the Rinda scan tool. It's worth it.
Sydwayz is offline
Old 08-18-2011 | 04:38 PM
newer 496,s have the water pressure in the power steering cooler,,,very easy to get to,,,http://www.mercruiserparts.com/Show_...Power+Steering part #29
TWIN-SPINS is offline
Old 08-19-2011 | 02:03 PM
Not trying to come across as a D1(k, but $100 is not that much when dealing with these types of boats. Granted $100 does buy a lot of beer, but it will also get rid of that pesky alarm you are dealing with. To me, that sounds like $100 well spent.... How much is your time worth? Figure you spend 4 hours (here and there) screwing with it trying to troubleshoot.... That $100, equates to $25.00 an hour........ Me, I'd rather spend that 4 hours on the water drinking the beer........
low_psi is offline
