496 Sputters on take off.... >
Old 08-20-2011 | 08:43 AM
Default 496 Sputters on take off....
Boat has been running fine. Yesterday during take off I noticed it sputtering a few time during take off...almost like it was running out of fuel. Once on plane it was fine. Each take off after that it progressively gets worse. The last time I took off, I finally got it on plane and at full throttle it will do the same thing....rev up to 4800-4900 RPM's sputter down to 4500 and then back again.....very noticable. At idle it is hard to tell but doesn't seem to have any sort of miss. I was going to swap plugs today and put some fresh fuel in. Any other ideas?
Baja_man is offline
Old 08-20-2011 | 08:57 AM
Does it have a coil?
PARADISE ISLAND is offline
Old 08-20-2011 | 08:59 AM
No coil, coil packs for each cylinder.
Baja_man is offline
Old 08-20-2011 | 10:31 AM
Moisture?
Had similar situation years ago...water remover solved it.
KachinaShadow is offline
Old 08-20-2011 | 10:33 AM
Originally Posted by KachinaShadow
Moisture?
Like dry gas in the tank?
Baja_man is offline
Old 08-21-2011 | 08:52 AM
Had to be bad fuel or simply low on. Put some fresh in yesterday and no issues.
Baja_man is offline
Old 08-21-2011 | 12:27 PM
BUP
Now you need also to change all your fuel filters since you had bad gas. All the fuel filters have pick up some of the debrie / water form the bad gas. This can and will cause fuel restrictions also rust inside these filters. Lean running conditions. Also any bad gas needs to be completely drained out before putting new gas in. Bad gas loses it octane value also.
Like any motor the 496 really hates to run lean. Also test your fuel pressure with a fuel pressure gauge at idle and at full throttle. Bad gas leads to fuel problems thru out the entire fuel system not just in the gas tank. Hope this helps
BUP is offline
Old 08-21-2011 | 01:02 PM
articfriends's Avatar
Baja man do you have a fuel pressure gauge so you can see your fuel press all the time?
articfriends is offline
Old 08-21-2011 | 05:48 PM
I do not have a gauge.
Baja_man is offline
Old 08-21-2011 | 05:54 PM
crayolacrazy's Avatar
sounds like plugs are loading up ,
crayolacrazy is offline
