Top speed is low >
Top speed is low
Top speed is low
Old 08-20-2011 | 10:09 PM
Default Top speed is low
Just purchased a 22' 1990 scarab with a 454 (supposed to be 400hp) and a Bravo One. Previous owner said that it ran 72 GPS with a 24pitch 4 blade so I went out and bought a brand new one.
Well took it out today and it only ran 58 (low fuel and only 2 people) on GPS. Also ran that at 4100 RPMS.
Timing is set to 8 degrees, new 750 marine carb, MSD distributor. Runs perfect, no pings misses etc.
Is there something else I should check? It seems even a stock 454 would push that to 65mph?
Any suggestions on what to check would be appreciated. Thanks
gumbya55 is offline
Old 08-21-2011 | 04:54 PM
Sounds like your low on HP. Meaning, the 400 he told you was off by about 75 or so. How many hours are on the motors ?
tinman565 is offline
Old 08-21-2011 | 06:42 PM
That's a big difference, but try fresh fuel
frankenstein is offline
Old 08-21-2011 | 08:12 PM
If it helps I have a 97 22 with the 454 injected stock and I have the 24P 4 blade. It is new to me so I maybe low due to inexperience in many areas but for reference I got 58mph GPS with 4 adults, 4 kids (under 12) and 1/2 tank of fuel.
pluguglyinhere is offline
Old 08-22-2011 | 12:38 PM
The 454 is a rebuild, with less than 50hrs on it. 750 holley marine carb and a brand new distributor. I mean it runs good, but just not getting the power I expected. And only 4100 rpms at WOT. Is that what you were running pluguglyinhere? Do you know what your timing is set at?
I do run higher octane fuel (always fuel up on land) and always add an additive (octane boost, etc).
Never pings or runs rough. I was just wondering about what kind of power it would need to be up around 65mph. I mean I thought stock 454's in those boats ran around that...
gumbya55 is offline
Old 08-22-2011 | 02:20 PM
new dist?
timing is probably off, you need to check total timing, most 454s like something like 36deg by 3000rpm
HTRDLNCN is offline
Old 08-22-2011 | 02:31 PM
trc2's Avatar
scarab
what are you trimming your outdrive to and does the boat have trim tabs
trc2 is offline
Old 08-22-2011 | 08:46 PM
Ive only been able to time it at about 700 rpms, and it's set at 8 degrees. Not sure how to time it that high with just a timing light and the marks on the tab over the damper.
Trim gauge doesnt work but I trim it to the point where the outdrive comes out of the water, then bring it back. I do have trim tabs, boat seems to chime walk just a bit with the 4 blade...but at 58mph it doesnt feel out-of-control.
gumbya55 is offline
Old 08-23-2011 | 12:14 AM
you need to check it at higher rpm to make sure dist is advancing correctly or you will be down on power.
here is a post on procedure:
http://www.offshoreonly.com/forums/d...procedure.html
HTRDLNCN is offline
Old 08-23-2011 | 08:52 AM
Ok thanks. Any suggestions on a timing light for advance? It has no vacuum advance. I've attached a pic!
gumbya55 is offline
