Go Back  Offshoreonly.com > Owners Forum > Powerquest
leaky pop up cleats?? >
Old 08-22-2011 | 09:39 PM
Default leaky pop up cleats??
I am getting close to an agreement on one of the two 38's I am looking at. One issue came up that I would appreciate some input on; The one boat has pop up cleats and the owner stated that they naturally leak into the front side compartments and then back to the bilge. Thus, anything you store in the front storage areas gets wet. Is this true, or is there another issue with this boat? Seems crazy to me to engineer a system like this???
vista268 is offline
Old 08-23-2011 | 08:48 AM
Mentalpause's Avatar
Pop up cleats I've had on my last two boats never leaked. Neither were PQs, but I'd think there is something wrong. You may want to post the year just in case a certain brand used in a certain year had issues.
Mentalpause is offline
Old 08-23-2011 | 09:57 AM
Wally's Avatar
Were doomed!
there should be a cup under the cleat and theres a drain line you can connect and route to where you want it to go....maybe they either didnt install the cups or didnt bother with hooking up lines to them....
-Wally
Wally is offline
Old 08-23-2011 | 09:08 PM
It is an 03. I looked at an 02 that had them too, but the issue never came upon that boat.
vista268 is offline
Old 08-24-2011 | 06:51 AM
on my 03 Revenge they never installed the hose that Wally is talking about..I had to do it myself..easy fix..must have been a Friday boat
boatnt is offline
Old 08-24-2011 | 08:03 AM
Airpacker's Avatar
CP marine has some nice little thru hull fittings to attach the drain tubes to. Best NOT to send any more water into the boat IMHO. I mounted one directly below each drain cup on my eliminator. 3/4" polished SS dome head is all that shows on the outside of the hull.
Airpacker is offline
