Fountain 27 502 MPI Vapor Lock - Booster Pump Install Help >
Old 08-23-2011 | 07:30 AM
Default Fountain 27 502 MPI Vapor Lock - Booster Pump Install Help
I've also posted this in the Fountain Owners forum, but thought I'd cross post for install on other brands.
I just received the booster pump kit referenced in Mercury Bulletin 99-7.
I started to loosely plumb the system last night, but prior to hard mounting the brackets, thought I'd ask for some advice.
Anyone install this kit on a 27 (or other Fountain) before? Any dealer techs here? Does your 27 have this kit factory installed?
I'd like to install the pump and filter as close to factory location as possible (if, in fact, that's the best location).
Pics would be great. Thanks!
ALL_IN! is offline
Old 08-23-2011 | 10:20 PM
I just plumbed the return line back to the fuel tank instead of the fuel filter per Eddie Young's instructions and cured the vapor lock on my 454 mag MPI. Took about 15 minutes and $10 worth of fittings and hose. Most people would never even notice that it has been done.
snapmorgan is offline
Old 08-24-2011 | 11:52 AM
Do you ever go to Dam 48 or JB Beach?
I'd like to see your setup.
Terry
easyrider1340 (at) gmail.com
27' Fountain white with purple/yellow graphics
ALL_IN! is offline
Old 08-24-2011 | 03:02 PM
Used to go regularly. Purchased a place on Barkley this spring and have been keeping boat down there. I will be in Henderson tomorrow and Friday, If you would like, I can swing by and show you what I did. PM me your phone# if interested.
Joe
