Go Back  Offshoreonly.com > Owners Forum > Sonic
1988 30SS/31SS Porpoising >
Old 08-29-2011 | 12:32 PM
Default 1988 30SS/31SS Porpoising
Hey guys was wondering if anyone can help out here. I have an 88 30SS with stock 454's that I am guessing to be the 330's. I have run both the Mirage 23p 3 and the Bravo 1 24p 4's and the boat just wants to porpoise. I have to run the trim all the way down and sometimes even tabs too if I have many ppl in the boat? Very frustrating and I don't know what fixes it? Not sure if I am just that under powered or what? Any suggestions or info would be great thanks!!
Faster Daddy is offline
Old 08-29-2011 | 05:28 PM
GO4BROKE's Avatar
Bravo drives?
Are they properly aligned?
Is the bottem straight? You may have some rocker or hook.
Cavitation plates and skegs ok?
[img][/img]
GO4BROKE is offline
Old 08-29-2011 | 05:42 PM
Yes Bravo Drives. I think they are properly alligned. I measured them once and thought they were right, but will sure check them again if you have any suggestions? I need to check to bottom to see about the hook. Cav plates seem fine and the skegs only have a little missing off the rear lower corner?
Old 08-29-2011 | 05:45 PM
shortys will fix this problem !
DareDevil is offline
Old 08-30-2011 | 07:38 PM
GO4BROKE's Avatar
I'm leaning toward a bottem issue. Are there any heavy loads in the cabin that could be throwing off the balance? Also, what speed does this happen? The 31 does porpoise at some lower speeds if given any trim. Was it better with the 4 blades?
[img][/img]
GO4BROKE is offline
Old 08-31-2011 | 12:37 AM
That is what I am afraid of too. Nothing really heavy in the front. The very is used for extra life jackets, noodles, floats and couple other things, but nothing heavy. It is pretty much the same at all speeds. The only way I can get any trim out is if I tab down a pretty good bit. I am not real sure what the bottom should look like or how to check it to see either? I was told the 4 blade should help the problem, but I don't think there is much difference between the 3 and 4 blade props. Thanks again for even taking the time with this.
Old 08-31-2011 | 02:56 AM
BUP
too much stern weight and or a rocker in the bottom of the hull . Get a long straight edge out and put against the bottom from the last 8 to 10 feet of the hull. A hook helps sucks the hull down so alot of boat manu's add them in to help a hull plane better. A rocker can add a little speed and free up some hull but can make a boat porpoise. Thats what I would check. Good luck
BUP is offline
Old 08-31-2011 | 07:53 AM
it could also be WATER in the foam between the floor and core !!!! the older ones had that issue with the foam !
I still say u need to run faster and lift the drives...( NOT TRIM ) lift them ( shorties ) !!
mine had SBC and alphas...did 62 MPH max..never had an issue exsept the water in the foam !
Old 08-31-2011 | 10:47 PM
Ok great I will check that and see what it looks like. I will let y'all know what I come up with. Thanks again guys!
