tachometer goes crazy after 4000 rpms
My port tach is ok to 4000 rpms but over that the tach goes nuts like it has a short in it. I changed tachs and still has the same problem. The engines are 454 425 HPs with factory ignitions, any thoughts on this would be a great help!
I had the same problem with a brand new set of livorsi tach's , tried everything ,filters,differnt ground wires, resistors, and a shielded cable nothing worked so i tried a set of non electronic ones (old style) and they work great
Thanks for you input. We trouble shot the tach last night,tried the stb tach on the port still the same,ran a wire from the V6 module to the tach still the same,changed the V6 module still the same, double grounded the tach still the same only thing left would be the distributor. Also changed coils.
I have the same problem!..
My boat originally had the Thunder IV ignition, in tandem with an MSD. The MSD failed so we bypassed it to use only the Mercruiser Thunder IV. Ever since this bypass, my tach goes crazy over 4K rpm, just like yours. Let us know if you find the problem.
Thanks!
Julian
Thanks!
Julian
