454 330hp vs. 454 mag sound >
Old 09-01-2011 | 01:43 PM
Default 454 330hp vs. 454 mag sound
Why does the 330hp not have the same sound distance as the Mag.
My current boat has twin 330's and I think you could here my older 90 baja w/single mag from further away.
Both boats have built in swin platmforms.
scubbydoo80 is offline
Old 09-01-2011 | 01:54 PM
the Mag has a bigger cam and bigger heads (rec vs oval)
both will increase sound slightly.
HTRDLNCN is offline
Old 09-01-2011 | 01:57 PM
Default RPMs and more exhaust flow
Cam and valve train is the difference in the two engines. I suspect the difference is the mag pushes more exhuast with the higher rpms, thus louder sound travels a further distance. Pure speculation on my part and having had both engines. My modified 454 mags are very loud (more horsepower, louder, which means sound travelers further). Again my speculation. A 330 is pretty quite with stock exhaust, even when the exhaust is open above the water line.
pitts1313 is offline
