rubber exhaust couplers
if the exhaust is going through the hull you can use what ever size the current tubing is but in soft wall exhaust hose..if its going through a y-pipe then you will need to get the merc or sierra ones..
you can go to any auto store that sells Gates brand rubber hoses and belts---its called green stripe hose...probally 4in for your application --that runs about 25$ a foot....its Hi heat, hi temp spiral wired straight hose.
