water pressure >
water pressure
water pressure
Old 09-05-2011 | 02:07 AM
Default water pressure
V hull single / question what should my water pressure be?
DIRT173 is offline
Old 09-05-2011 | 03:02 AM
18 to 20 psi at full speed
sosatime is offline
Old 09-05-2011 | 03:16 AM
Thanks man I am in the zone!!
DIRT173 is offline
Old 09-05-2011 | 03:18 AM
At what point do you need blow off valves?
DIRT173 is offline
Old 09-05-2011 | 07:36 AM
Raw water or closed cooling?
Raw water I believe should be under 25 psi. Closed cooling psi can run as high as the low 40s.
thirdchildhood is offline
Old 09-05-2011 | 01:19 PM
Thanks for the info
DIRT173 is offline
