454 MPI LX not reaching WOT >
Old 09-05-2011 | 01:28 PM
MR252SS's Avatar
Unhappy 454 MPI LX not reaching WOT
Just replaced motor with a remanufeactured 454 Gen IV in my 97 Formula 252 SS. The intake manifold had to be replaced due to damage from original motor. The fuel injection system has been gone over and everything seems to be working as it should., According to the diagnostic computer all systems are functioning as they should, but I can not achieve 4600 RPM, can only achieve around 4000 RPM. Any suggestions?
MR252SS is offline
Old 09-05-2011 | 01:42 PM
Make sure throttle body is opening all the way since you had the linkages off. Next would be to send out the injectors for inspection and or cleaning.
Chris
Blueabyss is offline
Old 09-05-2011 | 01:47 PM
MR252SS's Avatar
Thanks Chris !!!!! I'm going to mention this to my motor guy!!
MR252SS is offline
Old 09-05-2011 | 03:09 PM
Ebay Ed's Avatar
my fuel pressure regulator died in the time frame i replaced my blowed up engine last year
www.bajaboatowners.com
Ebay Ed is offline
Old 09-05-2011 | 11:40 PM
MR252SS's Avatar
did fuel pressure fluctuate at different RPM or did you find problem through diagnostics?
MR252SS is offline
