drive stand/jack
Old 09-09-2011 | 11:15 AM
Default drive stand/jack
has anyone converted an ordinary floor jack or a motorcycle jack to an outdrive jack? Seems like that would be pretty easy?
supercat is offline
Old 09-09-2011 | 12:49 PM
I converted a trailer Tongue jack into a drive stand/jack. Bought a cheap engine stand from harbor freight for the base, a square tube, drop leg tongue jack, and 6' of 1" x 1 1/2" square steel stock. Total $ spent, $87. not counting welding wire of course.
I will never remove or install a drive without one again. I can remove a drive in 5 minutes, and install one in about the same amount of time....alone.
The result:
Philm is offline
Old 09-09-2011 | 01:16 PM
looks like this one huh ? lol....the only thing I did different, was to go with two bottom legs so the skeg wouldnt hit anything.
Attached Thumbnails drive stand/jack-outdrive-stand-1.jpg
tinman565 is offline
Dave M's Avatar
Veteran: Navy
I built one from an engine stand as well. Similar to philm's but mine does not raises up and down. I just raise or lower the trailer tongue to get the right height.
Dave M is offline
Old 09-09-2011 | 01:19 PM
Sydwayz's Avatar
Forum Regulator
Common homeade applications include buying a motorcycle/quad jack, and rigging up some taller brackets. There have been posts on this before. I built one out of 2x4s years ago that I have on extended loan to another OSO member. I think it's going on 7 years. I'm OK with it since I picked one of these up DIRT cheap from a marina that went out of business:
http://www.yardarm.com/marine_produc...installers.htm
Here is the best thread:
http://www.offshoreonly.com/forums/g...welding-3.html
Sydwayz is offline
Old 09-09-2011 | 01:32 PM
Sydwayz's Avatar
Forum Regulator
Check out these "cadillac" stands made by OSO member Roger 1:
Attached Thumbnails drive stand/jack-7222_101594286525742_100000255122732_41783_4185334_n.jpg
Sydwayz is offline
Old 09-11-2011 | 11:33 AM
rrentsch's Avatar
Registered User
If you don't have the resourses to build your own, I am still building and selling these. I have sold over a hundred units all over the country to boat owners and service centers. Everybody seems to like these jackstands. Here is a link to the add in the classifieds and a picture
http://www.offshoreonly.com/classifi...o20513-en.html
Attached Thumbnails drive stand/jack-single-drive.jpg
rrentsch is offline
Old 09-11-2011 | 01:32 PM
That is where I got my idea. I was going to go with that engine stand, but it was double the price of the one I bought.
BTW, I sized the distances on the stand so that I can have the jack fully down and the skeg is 1/2" from the center leg.
Philm is offline
Old 09-11-2011 | 01:52 PM
That wasn't from an engine stand...I made that whole setup myself. I used some extra tubing I had left over from another job, and just basically copied a dual leg engine stand. Seems a little more stable. Looks like we both used the same Harbor Freight jack...lol.
Old 09-12-2011 | 01:02 AM
Randy Nielsen's Avatar
Sydways, I had a small shop and servicing drives was a real hassle espesially with extended swim platforms, So I bought one of those jacks you have pictured & Ill never pull a drive without it again. Those things are awesome & with the big wheels they work on gravel too.
Randy Nielsen is offline
