Blackhawk drive
It's actually a great drive but setup was way to specific as to how they were used they were a victim of their own design. They require a very high x dim and a lot of rocker built into the running surface to feed the props. If it's a hull that is set up for it like the P29 Scarab then you,d have a pretty good boat.also keep in mind that if you damage a drive replacing it will be difficult and expensive but not impossible. I would not shy away from a boat with Blackhawks at all. Replacinging the drives with Bravos is an easy bolt on option but keep in mind the aforementioned hull mods that may be present because of the Blackhawk.
What are you looking at?
08 OPA High Points Champion
RickoShay,
Take a look at my 1996 Scarab P29 with twin small blocks. This might be something for you to pursue.
Todd M. Sutton
Smith Auto Sales & Leasing
1113 West Maumee Street
Angola, IN 46703
260.665.3440 (Office)
260.665.3399 (Fax)
260.760.8633 (Mobile)
www.smittysusa.com
Sent from Todd's iPhone
Todd M. Sutton
Angola, IN 46703
260.665.3399 (Fax)
www.smittysusa.com
i love roost
Think you will be happy. the 303 bottom/setup with the blackhawks responded VERY well from what I have read/heard. You are going to idle rather fast so if you have speed zone be aware but think you will be really happy with that setup. Think someone on here is making props for these also which I think is the only weak link with these with the exception of the drive case
...fyi..there was a very informative discussion regarding the BlackHawk drive, parts, props etc...over at Scream & Fly a little while back...good info on a very kool set-up...New and used props & parts sound like they are out there, and being developed, as well...
...My personal experience's in my friends 22' Donzi makes me a believer..."close" to 80 and drove super...
...that Formula looks/sounds mighty fine to me...
