Go Back  Offshoreonly.com > Owners Forum > Sea Ray
lets try again >
lets try again
lets try again
Old 09-12-2011 | 05:28 PM
Default lets try again
i have an 87 p32 with alphas,no mufflers and i get steam does anyone else get this.
ext2gtx is offline
Old 09-13-2011 | 06:47 PM
Steam on the water? my 27 does the same thing totally normal.
pachanga27 is offline
Old 09-13-2011 | 08:14 PM
almost sounds like a song My P32 does the same thing, so did my P22.....its normal
Flamingo 42 is offline
Old 09-13-2011 | 08:51 PM
i beleave your right because of the way the exhaust goes into one,so the next question has anyone tried to do anything to change the steaming like the thermostat housing or riser gaskets or newer water pump? this drives my nuts.
ext2gtx is offline
Old 09-14-2011 | 04:33 PM
I'm not sure how much yours is steaming...I did notice the cooler the air is or the colder the lake temperature the more noticable it is
Old 09-15-2011 | 03:42 PM
It's because the exhaust exits so close to the water where most thru hull's exit out the back. Gonna have to live with it unless you blow holes in the back of the transom and plug the factory holes. I've seen this and it looks horrible IMO.
Old 09-15-2011 | 05:02 PM
no it doesnt steam much just bugs me.i didnt no if you put more water in the exhaust if it would stop it?
ext2gtx is offline
Old 09-15-2011 | 05:06 PM
i figured it had something to do with pachanga exhaust.
ext2gtx is offline
