Paint Vs Gel-Coat
Old 09-13-2011 | 03:06 PM
Default Paint Vs Gel-Coat
I have a 22 foot Scarab that I want add some flash this year ...the gel coat is ok but could be better and has some small cracks in the gel on the deck . I want to redo the boat and fix her up . I want a poker run boat appearance but in a smaller version .
When I admire all these poker run boats are they all gel coated or painted .
What is better ...can anybody give me some suggestions ??
Thanks in advance !!!
Mopwr
Mopwr is offline
Old 09-13-2011 | 03:12 PM
Most of them are painted. Gel is tougher but fades quickly, paint doesn't fade as quickly, but does scratch much easier. Gel's harder to touch up than paint as well.
Mastercraft240 is offline
Old 09-13-2011 | 03:16 PM
Thanks Mastercraft .....Great Video ....Boats looks sharp !!!
Mopwr is offline
Old 09-13-2011 | 05:38 PM
Too Stroked's Avatar
If you're going to re-do your Scarab, I think you'll find paint is really the way to go. On an existing boat (out of the mold), it's just a much easier proposition with lots more flexibility in what you can do.
As for advantages and disadvantages, here's my opinions. Gel is much thicker than paint and thus can be rubbed, wet sanded and polished many times before you run out of material to play with. And for solid colors, it's actually easier to repair. As for flexibility, you actually have quite a bit. Just look at some of the west coast manufacturers and what they do with graphics in the gel. Some of it is mind boggling.
Paint (as I stated earlier) generally gives you more flexibility, but it's much thinner and thus a scratch that you might have been able to sand and rub out in gel ends up needing a re-paint. Virtually all of the really wild graphics (like AOD) you see on boats are done in paint. So, to each his own!
Too Stroked is offline
Old 09-13-2011 | 07:17 PM
Smitty's Avatar
Vinyl wrap it and then you can change it 2 years from now with a lot less costs.
Smitty is offline
Old 09-13-2011 | 10:10 PM
will paint hold up if left in water for a couple months
cig20 is offline
Old 09-14-2011 | 12:21 AM
Not below the water line. It will start to blister after about a week.
Even gel coat can start to blister if left in the water for an extended period of time without bottom paint .
Griff is offline
Old 09-14-2011 | 07:24 AM
This.
I have a buddy that does this and it is amazing what comes out of his shop. Has made me even think about when i pick up a boat.
Nate5.0 is offline
Old 09-14-2011 | 02:31 PM
How much for a vinyl wrap?
carcrash is offline
Old 09-14-2011 | 04:44 PM
I would have to ask.
If i do mine it's material and beers on me as he is a childhood friend but if i am not mistaken without calling him it'ts about $1k for a mide size 20' or so.
Nate5.0 is offline
