Mastercraft ski engine >
Old 09-19-2011 | 08:05 PM
Thunderstruck's Avatar
Default Mastercraft ski engine
My friend has a 1999 mastercraft ski engine with some sort of GM 350 in it. The motor is a V drive that has a hole in the timing chain cover.
Looking at the top of the motor it looks like the motor is fuel injected, there is no distributor. The intake has a small round cover that is locked down with a distributor hold down, i.e. there is no distributor at the normal gm 350 spot.
Can someone identify the 350 so we can get another timing chain cover? Is that an LS motor or an older version of a 350.
Thanks, Tom
Long time cult member.
Thunderstruck is offline
Old 09-19-2011 | 08:43 PM
LT1 marinized by indmar , Does the motor look like this?
haulinit is offline
Old 09-19-2011 | 08:48 PM
Yep, LT1. Do a bit of research before you tackle the timing cover gasket. It's a little more involved then then a regular 350. You should give the opti-spark a good inspection while it's apart too.
HaxbySpeed is offline
Old 09-19-2011 | 08:51 PM
As stated look at buying a aftermarket sealed unit, they love to go out on the cars from coolant and etc getting in there and ruining them.
haulinit is offline
Old 09-20-2011 | 06:58 AM
Thanks, I will take another look before we get into this.
Old 09-21-2011 | 01:27 PM
hey hax how's the weather out there???
adk61 is offline
Old 09-21-2011 | 03:09 PM
Not bad.. Starting to get a little chilly at night. Still on the water almost everyday though.
Old 09-21-2011 | 03:34 PM
BUP
Mastercraft also used the Cadillac Northstar engine at one time. Do not remember the years.
Post a pic if you can, also how did the hole get in the timing chain cover. Not seeing this motor nor the hole and its location in the timing chain cover would it be for a cam sensor ? Just asking not saying it is at this point nor ruling it out. Good luck
BUP is offline
