Ultra-High Flow CEA Turbine Wheels Announced
All-New Ultra High-Flow CEA Turbine Wheels Announced
Precision Turbo and Engine has announced the addition of all new, ultra high-flow CEA (Competition Engineered Aerodynamics) turbine wheels to their current product line.
Specifically engineered to produce massive power gains over older turbine wheel designs, usage of Precision's new CEA wheels typically results in an average increase of 30-45 horsepower over comparably-sized standard designs. Furthermore, spool-up time is improved when using PTE's CEA turbine wheels to further reduce turbo lag.
Precision's current 62mm turbine wheels will be replaced by the new 62mm CEA version whereas the current 65mm turbine wheels will be replaced with a newly-developed 66mm CEA wheel. Utilizing an enhanced design, the new ultra high-flow turbine wheels will come standard on all of Precision's 62mm and 66mm turbochargers that also feature the exclusive CEA compressor wheels, both ball-bearing and journal bearing versions, including the 5862, 6262, 6266 and 6766 units
Additionally, all current turbine housing offerings will be available with the new CEA turbine wheels.
Similar in concept to PTE's CEA compressor wheels which are machined from a 2618-aluminum forging for added strength, higher efficiency, faster transient response and maximum performance, Precision's CEA turbine wheels offer unparalleled performance and the best "bang for your buck".
The cutting-edge technology found in Precision Turbo and Engine's CEA turbine wheels and CEA compressor wheels is unlike anything else on the market today. PTE is committed to keeping racers well ahead of the competition by constantly innovating and engineering the most powerful turbos possible.
